peter2407
Looking at servicing the above, so downloaded the user manual. There is no reference to there being an impeller. Am i being thick? I expected all outboards and marine engines that are water cooled to have an impeller?
Thanks all. Lazy git questions - is replacing the impeller worth the aggro if the water flow is consistent? Plus, the manual says force the gear oil in from the bottom. I dont have z squeezy thing so can i pour itfrom the top?
My old Tohatsu 3.5 ...... reattaching the leg and getting the exhaust, gear shift and drive shaft all in at the same time can make you weep for a few minutes......
Is that the rebadged mariner 3.3 2t?
If so, the impeller is located at the bottom of the leg and is driven by the driveshaft. Take the lower gearbox off, undo the impeller housing (pressed steel thing) and slide the impeller all the way up the driveshaft to remove it. DO NOT pull the driveshaft out - the bevel gear falls off the end in the gearbox, requiring gearbox disassembly to recover and refit. Ask me how I know
The impeller is "locked" to the driveshaft by a loose floating steel pin. Tiny and super droppable, be careful you don't lose it when you slide the impeller up. Done mine twice now - not difficult, but a bit fiddly. Hardest bit is lining up driveshaft, water pick up and gear elector when refitting gearbox. You need a minimum of three hands!!
Edit and deleted.Is that the rebadged mariner 3.3 2t?
