R.Ems
I would say, more.Is a freewheeling prop more, or less, likely to become entangled with a rope or net than a locked one?
But then it would no longer be freewheeling!
On three occasions we have had rope tangles, all when motoring. None when sailing with a locked feathering prop.Is a freewheeling prop more, or less, likely to become entangled with a rope or net than a locked one?
How does the engine provide water lubrication? Mine is a traditional stuffing box with no water from the engine (which I understand is only necessary on a high speed motor boat). So it shouldn't damage the cutless.It will suffer premature wear if left to spin, as you rightly say it is due to the lack of water lubrication that the engine would normally provide.
But as others also rightly point out, the shaft speed is so low under sailing rotation the extra wear is likely to be negligable.
Regards the cutlass bearing, in reality it won't make much difference unless you are sailing across oceans. I would definitely follow what the engine/gearbox manufacturer advises as this could have much more expensive and faster damage.
Regarding the gearbox, I should do what it advises in your handbook. On my Yanmar 2gm20f, it rumbles a bit when freewheeling, but appears not to have done any damage. Locking the prop shaft is like driving a car with brakes binding and slows you down significantly specially on a long passage - I reckon 1/2 kn at least.
Owning a mobo it hadn't occurred to me that 0.5 of a knot would equate to 12 miles in 24 hrs, a significant impact and quite thought provoking. Thanks for pointing that out ???What does your engine manufacturer say?
Personally, I don't lock the prop as is what Volvo Penta say in the manual. Before I switched to a folding prop we did a wee experiment 'locked and unlocked' - locked we lost 0.5 kt, or 12nm in 24 hours just over two hours drinking time in the pub.
On 2 week ocean crossing, it's very significant 12 x 14 = 168nm or day to 1.5 extra days.Owning a mobo it hadn't occurred to me that 0.5 of a knot would equate to 12 miles in 24 hrs, a significant impact and quite thought provoking. Thanks for pointing that out ???
I thought that there were 14 days in 2 weeks. I suppose with the current airline delays at departure one might be a bit confused if one's holiday was cut short ?On 2 week ocean crossing, it's very significant 12 x 12 = 144 nm or day to 1,5 extra days.
I have seen it on a relatively new small mobo but not on a yacht. The boat was probably capable of 20 knots.Is fitting water scoops an option to lubricate the bearing it has been used in the past but not shure if still done
Ok .I am no expert BUT I do recall reading that it is a question as to the method of how you stop the shaft spinning. Forget drag. The advice I recall was NOT to put it in gear. Why , when you wanted to take it out you might require force.This will damage the clutch cone. My late friend did this while racing .Is a freewheeling prop more, or less, likely to become entangled with a rope or net than a locked one?
The answer to this is simple and is advocated by gearbox manufacturers. After sailing start the engine in either reverse or forward, which ever locks the prop. Then put it into neutral, without needing any force. We have been doing this for years.Ok .I am no expert BUT I do recall reading that it is a question as to the method of how you stop the shaft spinning. Forget drag. The advice I recall was NOT to put it in gear. Why , when you wanted to take it out you might require force.This will damage the clutch cone. My late friend did this while racing .
Later he had problems and had to have a new clutch cone installed. The cone cost around 800. My research at the time revealed that putting it in gear while sailing and then having to use pressure to disengage it resulted in damaging the cone . Yes the prop spinning would put wear on the main bearing in the gear box, however this would take considerable sea miles ( thousands ) before damage would happen and would cost far less to repair.
Because only one of them locks the shaft. In forward my Yanmar box continues to rotate under sail with my Bruntons prop. To get it to feather I have to select reverse to lock the shaft.If engaging a gear to prevent the propeller, why do people think it better to engage reverse gear and not ahead?
Thanks for explaining that.Because only one of them locks the shaft. In forward my Yanmar box continues to rotate under sail with my Bruntons prop. To get it to feather I have to select reverse to lock the shaft.
