ST840
Any ideas or opinions on copper coat ? I'm moored in SQ and have water all the time. Is it worth the money ??
Wot he said.if you plan on keeping the boat more than 3 years absolutely. total no brainer
good antifouling, very very smooth bottom so use less fuel, and osmosis protection too.
If you need to change your anodes that often I suggest you have other things to worry about and have lots of stray voltages around. Galvanic isolator?It's like Marmite, the people that have it can see no wrong and the people that don't can't see the benefit,
It's expensive to a apply, it has a long payback against trad antifoing. we lift a lot of boats and in my view it performsm no wherep near as well as trad anti fouling.
So where is the benefit?
If we are talking mobos it is essential to lift annually to check everything and to replace anodes.
With mobos it is preferable to lift, inspect and pressure wash partway through the season.
With copper coat you need to lift after 6 months to clean the weed off and check and replace anodes etc.
I would not go for copper coat on my boat and I know a number of people who are over costing theirs with trad anti fouling.
Yes, I thumping agree with you. It was almost two years from when our boat was last lifted, til it came out a couple of months ago. From what I found of anode wear, I reckon I need not lift again for close to three years.If you need to change your anodes that often I suggest you have other things to worry about and have lots of stray voltages around. Galvanic isolator?
Really important in my opinion is to take power off when not on the boat. Absolutely no need to leave mains power connected to boat. Just cannot understand why so many do so?
We went through this last year when we had all of our antifoul off back to GRP.
In the end our surveyor put us off having it done. He reckoned all it would do was trap any moisture already in the hull in there and most probably compound any later osmosis issues. Makes sense I suppose!
Eventually we opted for standard antifoul again. We have the boat out every winter anyway.
so without the coppercoat how does the water get out? (it makes no sense at all)
Can't comment on its value on a MoBo, but it works very well on a sailing boat provided it stays on. We had it from new on our previous boat - it had never seen the water till after the Copper Coat was applied. It was professionally applied and cost quite a few grand. When we hauled out to clean up after the first year, the boat was very clean, but it became obvious that quite a lot of it was falling off. We had sold the boat and the purchaser's surveyor didn't notice it - the last I heard, they were in dispute with both the surveyor and the company that applied the stuff a year earlier.
We did think about it on the new boat, but ended up opting for conventional anti-fouling. I must say that I did miss it earlier this spring when I was under the boat with a roller applying Cruiser Uno, but I will not be losing sleep wondering if my two or three grand of Copper Coat is shedding itself all the way down the Thames Estuary.
