boatmike
Following my previous post I am still trying to calculate the optimum props for my Aquastar 33. Searching for reasons why max RPM is down I investigated further and noted steam from port engine at WOT. Engine temperature OK and plenty of water coming through so I stripped down the exhaust elbow and found the "exhaust brake" (volvos technical term not mine) was sticking shut. This gismo is a solenoid operated butterfly which is supposed to close when starting and running at idle but opens when revs increase. Have only seen this on TMD41a and similar engines. When Volvo originally advertised the TAMD41a they made a big fuss that it met the very stringent emission requirements for use on Lake Constance. I think these abortions were their solution to achieving this on starting and serve no useful purpose otherwise. Interestingly both engines start and run very well although there are no heating elements in the cylinders for starting. The port engine one sticking closed has been causing the elbow to overheat and obviously won't reach full power with an exhaust restriction which is possibly why I can't get more than 3400rpm out of either engine and steam out of the port one. I have now removed all the carbon build up in the elbows water channels and will put everything back together and perform sea trials soon. My question is this however. As I see this gismo as unnecessary for normal starting and running, should I just remove the solenoid actuators from both engines and run with both exhaust brakes permanently open, or does anyone see a useful purpose in retaining them? Do later versions of the TMD on TAMD have them or is it just the early versions?
