rogerthebodger
That's up to you. In light of your question I just wished to pass on my experience.
The Jabsco pump only may not fit on the top of the horizontal pipe from the bottom of the bowl but the hozontal pipe from the jabsco will fit the bottom of the bowl.
TMC offer no obvious support for earlier models.
Hi, we haven't had chance to get down to the boat and investigate yet. Have you been to the tip yet?I do still have the old TMC sat here awaiting a tip run if the pump mech is of any use to you. The seawater inlet side is accessed from the top 4 screws ? You could undo take a look and see what condition the rubber gasket is in, there is a spring in there that needs to be working and in place. If the spring or gasket is knackered i could pinch out of ours for you, that may improve your situation.
No, it is still with us, if it is of any use to you, you could pm me.
