kashurst
It's off! that's all that matters!
good luck with the shaft seals
? you mean turn it round and fit the prop on the now flange side?"scottie said:
Are the shafts reversible ?
When I considered this for my Corvette the pitted area where the old gland seal sat if end for ended would have sat right in the outer cutless bearing where the sharp edges would have ripped the cutless to bits, so I had to replace the shaft (cheaper than any re-metalling process I could find).Those shafts with tapers both ends can usually be 'end for ended' so worn areas by cutlass bearing or shaft gland can run on virgin shaft.
