gregcope
Ah. If your DIY'ing from scratch ... I have flattened 15mm copper plumbing pipe - gives about the same ampacity as 25mm cable. You can drill/tap it, however it is quite thin for a tap. Copper bar would be better.
Reason I use those boxes (which are available cheaper on aliexpress if you can wait) is that you get the holes done and covers / mounting holes done for you.
