jrudge
Sure it does but other w. c can pump poop as well !
It was vilebrequins. I'm unable to erase the memory of that classic Porto-PostSteady - remember the underwear/bidet post -![]()
Portofino I don't have the energy for long argument based on stuff you've dragged from the net. Many builders have switched from Vacu to tecma on the same model boat, due to customers disliking vacu. There is no useful uphill feature of vacu. I have tecma deliberately pumping uphill in my boat with no issues ( I completely redesigned my black system- none of it is Fairline standard, including all pipe runs, materials, tank number and location, etc). The vacu system only has vac in the short pump between the WC and the vac generator. Down stream of that it pumps/ pushes the waste to the tank just like a tecma style so you still have to worry about up/down hill. You can increase the vac length and reduce the pushed length, but then you increase the length of time of the horrible noise on every flush. Your theory just isn't correct but I'm happy to agree to disagree.
It was vilebrequins. I'm unable to erase the memory of that classic Porto-Post![]()
I still contend they are an easier fit cum cop out in terms of pipe runs and relative tank height - reducing potential for regurgitation when the boats attitude changes .
I'd so why on earth did they or still do ? Builders fit a Sealand Vac bog (s) in the first place ?
These two statements are simply wrong.
Take my forward cabin toilet - the existing pipe runs about 4m to and from (thats at 8m of pipe) the space where Princess fitted the vac generator.
The new pipe run will be less than 1m.
And this ratio will be the same for the others that I'm replacing - the bilge spaces under our accommodation deck are literally littered with pipes - most of which can be removed if the vac system is thrown out.
And to "why are the builders still fit them.
It seems to me that they don't anymore.
Porto, whenever you come across two alternative boating equipment, say X and Y, and X is superior to Y, most often than not the reason why some builders decide to install Y is quite simply that they can purchase it at a lower cost.
Not that I'm sure it's the real reason in this case, but I struggle to understand your focus on this point anyway, as if the following equation would be valid:
Y is (was?) widely used = there must be a good reason = Y is better than X
I'm sure you will agree that the last part of this transitive relation isn't necessarily true, regardless of how good the reason is/was.
As I understand the debate so far, everybody agree that X is superior to Y in all respects, so I think it's fair to answer your question about the Sealand USP with another question: does it matter?![]()
Hello again,
Just to update you all. The timer suggested by Grubble on Oct 10, has been fitted and works perfectly, the timer is not especially accurate but its good enough. If the pump runs too long, the timer cuts the power to it, but resets when the main switch is turned off and back on.
