Fire99
The answer to that is to get PBO to run a comparative test - I'd be delighted to submit a Tiller-Hand for testing against all other mechanical tiller controllers.
These are all relatively simple devices - a mechanical brake working on a control line slung across the cockpit. They need to be as frictionless as possible when unloaded, lock solid when required and, where it is the objective to do so, allow a varying degree of resistance to the helm.
Any gear that lives on a boat needs to be durable and it's best if it is unobtrusive and doesn't take up more space than is appropriate to its benefit.
You can choose between the Tillermate, the Tiller Tamer (from USA), the Tiller-Lock, the Midshipman, my Tiller-Hand and a couple of others of more or less similar design to the rest. The Tiller-Hand is less than £20, you can spend up to £100 on others. I'd be happy for PBO to determine the best value for money but, also, to comment generally on the benefit or otherwise of tiller controllers.
I declare a commercial interest!
With a handfull of fairy dust, John appears out of nowhere.
Come on PBO.. Do a test.
That said, yours looks good V.F.M. John. Impressive stuff.
