mjcoon
It integrates with NMEA whereas the 10 doesn't. ...
Does that mean that it can be set to steer by the wind (assuming you have an NMEA wind indicator)?
Mike.
Mike.
On the other hand a clove hitch is freeMidshipman Tiller mate by Seamark Nunn, allows precise adjustment of the tiller at the flick of a finger. Absolutely invaluable for short /single handed sailing. OK not a true autopilot, but costs under £50 but I use mine much more than I use my autopilot on my Trident 24.
Ever thought about where the boat will go if you fall off?
I've just thought of an invention if it doesn't already exist!
Yes the better models can steer to wind or to a course from a GPS device. I've not met anyone who has done this but I've read a couple of people on this forum saying they do. It's useful mainly for long journeys though. On short trips you'll probably stay in charge even if you're not holding the stick by adjusting the course with the buttons on the unit. Others may disagree with this post, it's based very much on my opinion so beware
Unless someone can show me I am wrong, I believe that there is no wind input device for the Simrad TP models, only for the Raymarine ones.
Read it and weep ...
http://www.simrad-yachting.com/en-GB/Products/Tillerpilots/TP22-Tillerpilots-en-gb.aspx
The TP22 will steer to wind
It will steer to wind with NMEA input from other instruments but AFAIK there is no wind input device as there is with the Autohelm version. Which is what I wrote. It would cost me a lot of money to obtain NMEA wind information, far more than can be justified.
According to the manual the ST1000 uses a sea talk wind instrument as the source. I don't see how that differs drastically from NMEA other than using a proprietary protocol. You'd still need to buy the wind instrument and wire it up to the bus.
There used to be a stand-alone wind direction transducer for the ST1000 (and bigger?) no longer in production I think but they come up on Ebay from time to time.
See page 22 of ST1000 Plus & ST2000 Plus Tiller Pilots Owner’s Handbook www.bluemoment.com/manuals/ST1000Plus&2000PlusTillerPilot.pdf Raymarine pushpit wind vane (part number Z159)
That would appear to still be SeaTalk from the manual you linked to so I would expect it to cost roughly what an NMEA one would. I've found NMEA ones for £120 on MSS and these have the advantage of still being available. Any idea what the Raymarine one cost?
I think they were probably about £50. I remember seeing some bundled with the tiller pilot as a freebie. When I bought my Simrad one it had the remote control free on the same basis.
Firstly I'd land! Tiller pilots for boats are not designed for aircraft.Having read through these numerous and informative posts, no information has surfaced regarding vessel tonnage.
My 35ft tiller-steered timber gaffer displaces approx 14 tonnes. Even temporarily securing the tiller with lines enabling me (when flying solo) to venture out of the cockpit if but only for a few minutes is inviting trouble.
Does anyone have any info regarding a tiller-pilot heavy duty enough to allow me some respite?
