Tide predictions software
DAKA
7 Jan 2005
Nomadic
I m about to renew my Belfield Tide predictions software for £10.99 and just thought I best check if its the best one available currently ?
What do you use ?
Belfield is easy, you get local ports and tide graphs.
Very basic plotter with tide diamonds (arrows showing tide flow for each hour selected along with tide speed)
and a basic drag distance plotter tool for passage planning.
I want something to help avoid wind against tide in strong tidal flow areas.
Geoffs
15 Jun 2001
Wantage,Oxfordshire
+1 for Tidesplan11. Will be Tidesplan12 next year. Even better on iPad. The free version only gives 7 days look ahead, for £4.99 , I think it is, you get full version. I use it instead of Bellfield, nowt wrong with Bellfield, excellent value.
If you have an Apple device, iphone or Ipad, then Boatie is good too(maybe on Android). Gives inshore forecasts, synoptics and an excellent animated tidal flow map for Solent and South Coast, plus lots of reference info, oh and a marina guide.
Gwylan
31 May 2007
Moved ashore
Try WXTide32 - bit fiddly at first, then it's great and will do about everything you might need and it's free.
For the Android you can try Marine Weather by Bluefin - again versatile and free.
oceanfroggie
21 Aug 2006
EU27
www.derg.ie
Almanac and tidal atlas or diamonds. Works every time. No batteries, no wireless, etc etc.
OK, just call me old fashioned.
Yes carry paper bits for backup, but iPhone app more useable and less prone to user error. (eg UT v BST, reading wrong column, secondary port calcs done, etc). Even better on iPad for tidal streams.
dharl
24 Oct 2011
Pembrokeshire
www.mhpa.co.uk
agree prefer charts and books on the boat..;) however nice to have a good app so you can have a look at and do a bit of planning for the weekend while on the train home.....:cool:
DAKA
7 Jan 2005
Nomadic
When planning 80-140 nm I find it easier to have a full size screen (I dont own an Ipad) so I think the app would be fiddly , I looked at WXtide thankyou and I will use it as a standby but I think the belfield with the tide plotter still wins on value .
Thanks for everyones help and input :)
I used to find that weather altered plans without warning and I frequently found my self checking several departure time options for secondary ports and tidal flows for every 1/2 hour for a 120 nm cruise , this headache of calculations usually started after a night out say 2330-0030 and an error with a tidal flow of 180' was not uncommon .
Belfield has eradicated these errors and only an occasional French Daylight saving cockup has caused slight discomfort for an hour as the last bit of tide looses momentum.
dedwards
12 Sep 2003
Hampshire
Shameless plug:
In the next few weeks I'll be releasing an android tide app that displays UKHO data for the main UK ports for 2012 and is completely offline. No tidal stream support yet though.
see the link in my sig for details.
trooper
7 Sep 2010
Manchester UK
Belfield
I am thinking about buying the belfield software with tidal data - I have also looked at Nuno navigator which again looks like it will fit the bill - anyone had any experience (good or bad) they can share? I am looking to run from a laptop on board.
