Albert Ross
Your problem does sound very similar to mine, I don't have an auto prop just a standard 4 blade, the boat was hauled out yesterday cutlass bearing is fine, 2mm of play at most, no wear on the rubber inside the cutless bearing so I'm assuming that would rule out engine alignment aswell, does your noise happen frequently or just every now and then? I have a Borg Warner v drive box with a ford mermaid 180hp
It happens every time when engaging forward gear, when we have been sailing but not after being moored overnight (possibly something to do with the temperature of the gearbox?), and never when engaging reverse. If you explore the web, there are lots of people with the identical problem. It is important to note that this is a really loud clonking, banging noise, not a little rattle. It lasts for about 10 seconds after engaging gear.
