jblakes
Our Volvo KAD44 port engine jumps i gear while on tick over! This happened while i was on the pontoon and suddenly the boat started moving about while luckily still be well tied up. The mechanic has changed the throttle potentiometer but the problem seems to keep on coming back especially when mooring!!. We also have an intermittent drop in revs from 3250rpm fluctuating 2250rpm while cruising. The mechanic has also replaced many of the connections on the engine too. I would appreciate any thoughts on the matter as this is a very dangerous fault that needs a permanent fix?
