brokethebox
I work on a sail training boat which is gaff rigged and i have wee problem you guys may have an ingenious solution to!
Our throat halliard has a four foot length of chain from the mast band at which it is attached to the upper throat block. There has been a little damage caused by that upper throat block then tapping lightly on the mast over time and breaking the varnish layers there, allowing water in. The damage i have fixed (no big job as really had only cracked the varnish and caused about 1/2mm of dampness).
I guess my first question is why the length of chain and not run the upper block directly from the crane on the mast band. (Other than that i would need an extra 24' of halliard).
And secondly, any hints on stopping the damage from reoccuring? Had thoughts on a lower band to get rid of the need for the chain but this seems costly, or of having a larger crane welded to the existing mast band to hold the offending block further from the mast.
Any help would be much appreciated!
James
James
