Bouba
I’m of the opinion that before you hit the water you want the prop to stop spinning. Anything else could see you make contact with the blades
That only really works with a remote/console set up where the kill switch is well forward in the boat.I’m of the opinion that before you hit the water you want the prop to stop spinning. Anything else could see you make contact with the blades
If it’s in gear then it will slowdown very quickly and might stop altogether when it reaches bone. But bone alone will not stop 300 horsesNot going to happen. The prop carries on spinning for far longer than that.
The real purpose of a kill cord is to stop the boat running away, then circling and hitting anyone in the water, or anything else.
Would be freakishly unlucky to hit the prop going in over the stern or rear quarter. I'd expect with the sort of speed needed for throwing someone out, the boat will be gone before they hit the waterIf it’s in gear then it will slowdown very quickly and might stop altogether when it reaches bone. But bone alone will not stop 300 horses
Even with my torqeedo I think about lengthening the kill cord. But sitting on the tube while holding on to the engine always makes me think againWould be freakishly unlucky to hit the prop going in over the stern or rear quarter. I'd expect with the sort of speed needed for throwing someone out, the boat will be gone before they hit the water
A jet ski is probably the only propulsion that is safe to the user. But a series of unfortunate events can turn into tragedy. Don’t they have electronic kill cords nowadays ?Just as an aside, some years ago a jet skier fell off his ski at Herne Bay, on the North Kent coast. Unfortunately, his kill cord was a bit loose, and slipped off his ankle or wherever, with the throttle stuck fully open.
The jet ski continued on its way for 15 miles across the Thames Estuary, reported to the CG by various pleasure boats and passing ships.
It eventually collided with the boom at Shoeburyness, which was fortunate as it would have caused a certain amount of chaos among the boats and swimmers off the Southend beaches.
True could be more dangerous with a slower boat I guess. But still the prop is a fair bit tucked out of the way and moving quickly away in the opposite direction to the falling person. Can't picture being likely to hit the prop unless maybe flailing arm reaching back in that direction maybe trying to grab the boat... Or maybe, if sitting far back on the port tube, engine hits something and kicks round turning the boat rapidly to starboard, tiller handle pushes to port, person slides off the back while trying to hold on so stays close to the boat and engine runs into him. As he's still so close one kill cord might not work either. freakish though.Even with my torqeedo I think about lengthening the kill cord. But sitting on the tube while holding on to the engine always makes me think again
I used to go on a friends stand up jetski late 80s. No kill cord, engine used to tick over and come round in a circle so you didn't have to swim after it. Worked a treat.Just as an aside, some years ago a jet skier fell off his ski at Herne Bay, on the North Kent coast. Unfortunately, his kill cord was a bit loose, and slipped off his ankle or wherever, with the throttle stuck fully open.
It eventually collided with the old anti-submarine boom at Shoeburyness, which was fortunate as it would have caused a certain amount of chaos among the boats and swimmers off the Southend beaches.
Even this probably drunk idiot looks like he just cleared the propA jet ski is probably the only propulsion that is safe to the user. But a series of unfortunate events can turn into tragedy. Don’t they have electronic kill cords nowadays ?
As ever a mundane question ends up seeming quite interesting. I was trying to find what range you have to be away from the engine for a wireless one to activate and shut off the engine. Is it much more than the length of a kill cord? Yes way longer. This one is 2 seconds after the person has gone in the water OLAS Guardian wireless engine kill switch stops the boat in secondsThere are several US makers of wireless kill switches. No cord required. The are triggered either by distance or immersion.
No, the idea of a kill switch is not to stop the engine while you are falling. Stopping the prop that fast would require a brake, like a chain saw, and that is not how they work. It is to stop the engine before the boat circles back around and runs you over.
USCG kill switch requirement
"Engine kill switches considerably prevent runaway boat incidents and the deadly threats they pose. ..."
