KevinV
Agreed, although a good thermos is a viable alternative day sailingI think long term I really want gimbals. I've always had it on other boats. I always seem to be making tea at 30° on a reach.
So they do.That's interesting. But mostly opinions seem to favour gas.
I'd rather have a fitted, gimballed stove, mostly because it feels more "proper", but the reality is that the "temporary" gas canister jobbie I have is fast, cheap enough to run and has the bonus that I can take it outside to cook smelly stuff
I really like having a properly gimballed cooker, but that is hard to achieve in a small boat, and I am not convinced it is necessary..
I had a gimballed cooker on a small boat, but the daft frame supporting the cooker (intended to allow the cooker to be lowered and less in the way when not in use) would very occasionally collapse, dropping the cooker a few inches, which was very hazardous. Even without this problem, the restricted space available on the boat meant that that the cooker couldn't swing far at all before reaching an obstruction and stopping abruptly, and when the boat was in motion this would result in spillages. As a temporary measure, I removed the frame and fixed the cooker direct to the base underneath. I found that with pan clamps this was actually satisfactory to greater angles of heel or rolling than with the gimbals (I think the only time we couldn't use the cooker was the two times when the tide had gone out after we'd gone aground, leaving the boat lying on its side*), and given the lack of space to have it properly gimballed with adequate clearance I never changed it in years of extensive cruising.
(*We'd learnt our lesson by the second time. As soon as we realised we weren't getting off before the tide went out (and unworried about drying out on mud), the kettle went on, and tea was made. We then each found a book to read and a wedged ourselves between a berth or cockpit bench and its adjacent hull or coaming, relaxed and read and snoozed until the boat came up far enough to get the kettle on again.)
Atypical situation, Sods Law wise, because you are trying to blow it up.Ybw did a video years ago of trying to blow up a boat by leaving the gas on to fill a boat.
They failed a few times before blowing up the boat because they could not get gas to air mixture correct.
On our first yacht we fitted with a metho spiriit stove. It was an excellent solution. We used this for cruising, including times when we were over a couple of months away from shore facilities.
Unfortunately, there do not seem to be any drip-fed methylated spirit stoves available for purchase. This is a pity. They worked well.
They were a very reliable and effective solution for a smaller cruising yacht.
