Topcat47
Well there you go. Mind you you'd have a hard job seeing the trees on either end of the lines these days....
From "BRITISH CHANNEL PILOT CONTAINING SAILING DIRECTIONS FROM LONDON TO LIVERPOOL" printed 1839 - author/editor J.W.Norrie...
No real idea, but I'd guess maybe trees on Butser Hill ?
Do you mean Portsdown Hill? Butser Hill is over 10 miles inland!
Well I never...
"Spithead. To sail into SPITHEAD westward of the Nab and eastward of the Princessa and Warner the leading mark is Nelson's Monument on with the east end of the trees on Portsmouth Lines bearing about N E...
I don't understand the reference to N E, Nelson's monument bears N W from the area of the Nab/Princessa?
The Hilsea Lines I would have thought wouldn't be any good to form a transit, they would not be visible. Maybe the fortifications along Southsea sea front would be termed the Portsmouth Lines?
Just been out today, the bright yellow section must extend 4 odd meters above HWS.
Not sure what the problem is TBH
I think anyone not trying to be argumenative will spot it's less than that; and anyway don't you get the simple idea the things should be easy to spot ? - Yotties & boaties 365 days a year-24/7 - lives in danger; Carrier drivers yet to be decided and only careers in danger a couple of days a year if it's a nice sunny day for cocktail parties...
"This monument or pillar is painted red and white perpendicularly in order to render it more conspicuous."
Few other references as well... here: https://books.google.sk/books?id=c4...ILTAB#v=snippet&q="Nelson's monument"&f=false
I too am local and have been some what intrigued by the pilots instructions.
Nelsons Monument would line up nicely with Southsea Castle and the adjoining lines to the east of it which would clear the Princessa shoal, Bembridge ledge etc etc.
The only way to get a NE bearing on the monument would be to pick up and carry your boat over the Isle of Wightso perhaps it is a typo.....
I'd suggest they are just as, and if not then more, visible as other marks on the Solent, but if that concerned one can always just keep just outside the main channel and therefore be well way from them
OK, just try to imagine coming from the Western Solent to Chichester, in fog.
Even with a plotter and / or radar, do you go through the uncharted, Navy camouflage grey posts to the Dolphin Passage, or risk it among the possible big ships between the forts..
The posts are fully charted, if you are up to date with your corrections.
If you can't find (and avoid) those leading marks then I very much doubt if you would find the Main Passage through the submerged barrier.
You do have a tendency toward hyperbole at times.
