coopec
N/A
The Firefox popup blocker doesn't stop the ad's. A quick check using the task manager, with and without the ad' blocker, shows that the ad's are not only using the main CPU, but they also impose a noticeable load on the graphics engine.
I'd suggest you both try uBlock and see what difference it makes, easy to remove it if you don't like it.
I definitely will take yours (and others) advice to install a blocker.
Five minutes ago I was looking at SSD (Solid State Drive) to use instead of the electro/mechanical disc drive. I can't believe how incredibly cheap they are.$115 for 500GB. I have to do more research to get a better understanding.
Jan 16, 2019 - SSD vs. HDD Speed and Performance. Solid state drives (SSDs) are faster than conventional hard disk drives (HDDs) and they are also more reliable and use less power. ... Solid state drives have dramatically faster read and write speeds when compared with hard disk drives.
https://www.enterprisestorageforum.com/storage-hardware/ssd-vs-hdd-speed.html
