Thermal vs Magnetic Circuit breakers (Float switch)
Scubadoo
16 May 2001
Hampshire / Solent
Hi All, Looking to replace a faulty shower pump float switch with a Whale Bilge Water level sensor (no moving parts etc), but reading the instructions it clearly states "Do not use thermal circuit breakers with the BE9003(B)/BE9006(B). Magnetic breakers must be used".
Can anyone explain why? my boat and I think probably many others have Thermal circuit breakers, so it looks like a non starter for me as my existing float switch is connected a Thermal breaker. It also seems magnetic breaker aren't so readily available like the Thermal units.
This is the unit: Whale Bilge Water Level Sensor BE9003
Thanks.
Magnetic breakers will trip immediately the current is exceeded. Thermal breakers will have a delay while they heat up and will also vary their sensitivity with ambient temperature. This delay is often useful to allow a current surge when the motor starts up.
Often the two are combined to get the best of both characteristics.
I'm not sure why you can't use a thermal breaker - you would have to ask Whale. I can only think that the electronic switch is only rated for sufficient current for normal use and it could be damaged by the surge that could get through a thermal breaker.
RS and CPC Farnell sell a variety of circuit breakers from suppliers such as ETA and Carlingswitch. You might find one that matches your existing switches.
If this were me I would use an A or B curve breaker. That said a bilge pump is still a motor so possibly too much surge for an A rated MCB, but I doubt most bilge pumps will require 20Amps. So if your pump requires say 10Amps then I can't see why a 12 - 16 Amp MCB would not work adequately.
Thank you for taking the time to explain, very helpful. I am reluctant to replace my existing breaker and the added hassle as I was simply thinking of swapping over the float switch. Thanks for the vendor references, will have a look.
I think my other option would be to add an inline fuse at the float switch.
Thanks, the bilge pump is low amperage, max 4amp.
Fuses also come with different characteristics like the A, B, C, D ratings of MCBs. If the amp rating is followed by an F it is a fast fuse. If followed by a T it is a time delay anti-surge fuse.
If your pump is only 4A and you have a 5A or 6A thermal trip I'm sure that will be fine as the current will trip well before 20A.
