Tranona
A smoky old Seagull 40+ (also notionally 55lbs thrust) will comfortably do that It takes very little power to move a slippery boat like that at low speed.
40lb of thrust might move a well designed hull at low speed in calm conditions, but it doesn't take much inthe way of wind and waves to overcome 40lb. It will also take a long time to gather speed or to stop the boat.I have had this debate with numerous members at my club, usually while they are swearing and cursing their petrol OB that won't start. They could get a 40lb thrust bison and 50 ah lithium for around £300 which would more than suffice as a shore to yacht motor for their tender.
Ive got a HH27 and would be interested to see how it performs with the 24v Bison (100lb thrust) on an outboard mount. Especially given the feckin issues I am having with the sea water cooling on the Beta 10![]()
40lb thrust for a small tender would suffice most of the time. A 55lb thrust Bison has pushed my Skipper 14 (70Kg) tender with about 200Kg of crew plus gear at 2.5kts against both wind and tide. Before I went Lithium I got caught out with a lead acid but still found the Bison a useful row assist with it set at low speed (1&2). The LA simply couldn't provide the amps for the higher settings.40lb of thrust might move a well designed hull at low speed in calm conditions, but it doesn't take much inthe way of wind and waves to overcome 40lb. It will also take a long time to gather speed or to stop the boat.
A 50Ah LiFePO4 battery probably holds enough energy to meet a lot of what I want from a tender motor, but watch the current rating. Many are internally limited to 50A, so a 50lb trolling motor is typically right at the limit.
I'm hoping my Yamaha will do another few years, so a bigger battery will be affordable.
If you're claiming 2.5knots over the ground against the tide, that doesn't really mean very much unless you know what the tide was!40lb thrust for a small tender would suffice most of the time. A 55lb thrust Bison has pushed my Skipper 14 (70Kg) tender with about 200Kg of crew plus gear at 2.5kts against both wind and tide. Before I went Lithium I got caught out with a lead acid but still found the Bison a useful row assist with it set at low speed (1&2). The LA simply couldn't provide the amps for the higher settings.
Petrol outboards that frequently refuse to restart* is a fail too.If you're claiming 2.5knots over the ground against the tide, that doesn't really mean very much unless you know what the tide was!
If you're claiming 2.5 knots through the water, that doesn't really impress very much.
A Skipper 14 will be less draggy than an inflatable similarly loaded.
Waves slapping on the flat bow of a flubber don't help!
Fair comment that a 100Ah lead-acid battery will be giving a bit less voltage than a 100Ah LifePO4, unless it's fully charged, at 50A discharge.
It should not be a huge difference if the battery is in good nick.
"Suffice most of the time" is a fail.
Adequate power in a tender is a safety issue IMHO.
The tide in many West Country rivers runs quite swiftly.
Do you actually know it's drawing 600W at 4 knots?For comparison my Marine 3.5 longshaft pushes the skipper along at 6.5kts. The 55lb thrust (draws about 600w) will push it at 4kts. (in both cases light winds / HW slacks)
I have at home in the water butt with a clamp on ammeter plus volt meter. It was drawing 48 amps and 12.3vDo you actually know it's drawing 600W at 4 knots?
It would be interesting to see these things running with voltmeters and ammeters.
55lb at 4knots would be about 500W of mechanical power. Delivered by the propellor.
I agree...a repair to an electric outboard can be devastatingly expensive... and very difficult to find anywhere to fix it. But as a rule they are more reliable
Yes....but they struggle to make much headway in any sort of chop.Trolling motors are cheap.
