Blueboatman
Nothing sinister about the reasoning then
That sounds plausible. Any fishing historians about?
And btw, galleys should always be on the port side: when you heave to it should best be on the starboard tack with the cook on the low side above his cooker. Always easier to control pots and pans downhill.
Similar reason for the throat halyard on a gaffer to be on the starboard side of the mast (and I guess for the single main halyard of a bermudan sail to be there too). The throat halyard is the one you mostly need to work with when reefing, and if you're hove to in order to reef then you will want to be working from the uphill side.
Well Peak halyard too, you can't really use one without the other. At least I can't![]()
Surely you've all noticed the bloody traffic lights nailed to every boat on the sea?! Green light = go, red light = stop and give way. Simples.
Certainly that's how I remember the crossing-under-power rules, but do they work for port tack / starboard tack? And which came first, the priority or the lights?
I seems to me more likley to be because the port tack boat can bear away to pass port to port, whereas the stbd boat would have to head up and compromise his control.Port tack gives way to starboard is because the boat on the port tack has the helm higher in the air than the boat on stbd tack hence better visibility for that helm.
Boo2
Bear in mind that until relatively recently, the rule only applied between two boats on the same point of sail. Previously, a boat reaching on starboard tack had to keep clear of one close-hauled on port, while a boat reaching on port tack would stand on to one going downwind on starboard.
My BIL belived that.
How old is he?
(It's in my Admiralty Manual of Seamanship 1937 edition.)
Sounds the best so far.I seems to me more likley to be because the port tack boat can bear away to pass port to port, whereas the stbd boat would have to head up and compromise his control.
It seems to me more likely to be because the port tack boat can bear away to pass port to port, whereas the stbd boat would have to head up and compromise his control.
Yes but if the starboard tack boat bears away they will pass green to green, so disobeying the port to port rule.Surely either a port or starboard tacker could bear away to pass behind t'other equally easily?
Britannia ruled the waves.
Well... I was in a taxi in Le Touquet that was totaled when a car nipped out of a narrow road on the right. Priorite a droit still ruled then. Thank god (or any other choice of being) it has mostly been binned. Except in a local town, where the insurers do OK.It is more like drive on the right and give way to right like in the rest of the civilized world![]()
