Poecheng
We need a system to pair up the "sailors" with the "boatyarders"
I want first dibs at a "boatyarder" in Brightlingsea please
Most Boaryarders are not sailors,have little practical experience of sailing & that reflects in how they fit the boats outWe need a system to pair up the "sailors" with the "boatyarders"
Anyone who fancies a few weeks in Greece helping make sense of my amateur attempts to sort my boat out would be most welcome!
There was a sad case in a boatyard where I spent a lot of time working on my boat. There was a home build ferro ketch (big, 50'+). She had been built in North Wales somewhere and the guy who built her ignored the designers plans and added an extra layer of concete which resulted in her floating well down on her lines - I believe there was only a few inches of freeboard. Anyway, another guy bought her, probably very cheap and moved her to our yard. He spent years grinding down inside the hull and refurbishing her. A local naval architect had advised against this course of action but the new owner carried on regardless. Launch day came, after maybe 5+ years work and sadly the architect was proved correct. There was a small increase in freeboard but not very much. Never got to know the owner but apparently he was not (or appeared not to be) overly concerned and sailed off into the distance.
It seemed that having got as far as Brittany, he'd decided that a few things on his yacht 'weren't quite right', so he'd sold it and returned to build a new one without said faults.
One big factor in the everlasting boatyard tinkerers is crazy ideas. People who know better than the rest of the boating world and try to put their wacky ideas into practise.
When I built my tri in the 1970s I rented a space at Andrew's boatyard - now Thornham marina - when the rest of the yard was just storage. Seeing me building a row of 40-foot hulls obviously triggered something in people and before long there were DIY projects all over the yard. The one that shocked me most was a guy building a Wharram. He was a laminator by trade with apparently little knowledge of boats. He had made a male mould out of pine and hardboard and had laminated the first hull over it. He had watched me laying up the PVC foam core and laminating both sides and decided this was the way to go. He proudly told me he was going to make his into a 'hardboard sandwich'. I told him that moisture would get in and the hardboard would swell and disintegrate but he assured me he would laminate the inside up to the waterline and paint the rest and it would be fine. By the time I launched and sailed away he was still in the early stages so I never found out what happened to him. The best result would have been for the hardboard to start breaking down before he finished.
Some of us do get these projects finished! 8 years it took me and it was only a 20ft boat. Never again though. Enjoy the sailing too much to want to go back to building. Only one really important thing kept me going. The walk-in / walk-away factor. If what you're building isn't beautiful to you each day you work on her, then you're lost and you'll never finish it
The saying in aviation is "If you want to build, build. If you want to fly, buy." In general putting the time it takes to build a glider, light aircraft or boat into shifts at your local filling station will get you something far better than you could make yourself.
I had all sorts of plans regarding her refit and bits I would add/modify.
Only about half of them made it to reality. The rest were abandoned because they turned out to be impractical, too expensive or a combination of the two.
