GHA
You don't find that your magnetic compass bearing wobbles about a lot, especially in rolling seas?
Makes no difference, windvane doesn't look at the compass
Errr not really... what will you steer to ?
GPS does show direction, too.
true, but it does wobble about a lot, especially in rolling seas
Makes no difference, windvane doesn't look at the compass![]()
You may find that if you use the wind direction to navigate by, you won't always get where you thought you were heading.
Yes!! but you will do it efficiently
As for magnetic deviation, my compass is so far out of sync with any thing, other than the hand held VHF in my pocket or the metal fuel can in the stern locker that 20 degrees either way is chicken feed.
Standard procedure is to just sail south until the coast of France pops up & then decide where it was I really wanted to go
Perhaps not much has changed, then, since the Vikings just sailed East (because they could maintain a latitude) until the coast of [UK/ North America] popped up and then decided where it was they really wanted to go!
And there we were, thinking it really mattered where the North pole was sitting.
I think if they had sailed EAST, they would still be looking!
There isn't a good, finely datable sequence through a change, so we don't know how long it takes - rapidly by geological standards, but that's between 100 and 1000 years.
Bit of a simplistic calculation, but 50km/yr gives 400 years.
The situation in the south is similar, but the poles are not antipodal, so it isn't a mirror image of what's happening in the North.
That answers Dolabriform's question in post #20 then.
I can't wait to see the amendments to all the RYA training on how to correct charts once this has happened![]()
There is also the question of nomenclature. Is our current North Pole to be renamed 'South', so that all the world's magnets can keep their labels, or is it to stay as 'North', in which case all the magnets will be wrong? Who decides this? Is it the IMO or a bunch of geophysicists somewhere?
It's worse than that - the North Magnetic Pole is actually a south pole - think about it, opposite magnetic poles attract, same poles repel. So, to attract the north pole of a magnet, the Earth's North magnetic Pole must be a south pole!
But perhaps the North pointing end of a compass is actually a magnetic South pole and we only call it North because that's the way it points.
Richard
Incidentally, the position and motion of the magnetic poles is much more complex that people usually imagine; the Earth can't be modelled as a vast bar magnet. There are two poles - the Geomagnetic pole, which is where compasses point, and the Dip pole, which is where the magnetic dip (the angle of the lines of force to the surface) is vertical. The North Geomagnetic pole (the once responsible for variation) is actually not moving very much; it's in the Canadian Arctic Archipelago. The Dip Pole is scooting off over the Arctic ocean at a rate of knots, and is actually nearer Russia than Canada.
That's interesting. I have to admit I'm struggling to visualise the field lines where the geomagnetic pole and dip pole are separated by a significant distance. If you were between them where would a compass point?
I presume it is the geomagnetic pole which would also determine the direction of magnetism of stripes either side of a mid-ocean ridge. So if that isn't moving much do we other evidence that points to a likely flip in the near (relatively speaking) future? After all, the dip pole could've gone for a quick spin round the Arctic in the past but if it hasn't left any evidence how do we know whether it is normal or the start of a flip.
PS maybe a magnetic pole gybe is a better term that a flip. Especially if it involves a dip pole.![]()
It is an error to assign an isolated polarity to the ends of a magnet.
