Anchoring is my yachting achillies heel and this can be attributed in part to the woeful undersized clip-on bow roller that my racer/cruiser is currently equipped with. This seasons main mission is to spend more time at anchor using a brand new bow roller that I have to design and get fabricated. One upside is that I can remove the clip-on bow roller socket which then gives me a clean sheet for a custom replacement bow roller.
So far I have concluded:
- My plumb stem will require about 8" to 10" of projection, I might get away with less because when my new furlex was fitted last month an extra link raised it well above deck height to avoid obstructing the anchor shank during launch and stow operations.
- The most mechanically demanding moment during anchor retrieval is when the top of the shank pivots over the roller from vertical to horrizontal. A large bow roller wheel diameter helps but a double roller is much better. Rocna recommend a 10cm diameter for their 15Kg anchor.
- Which leads onto whether a pivoting (hinged) double roller design is needed and this is my main point of confusion. Would I be correct in thinking that a modern anchor design such as my 16kg Delta will self launch and stow on a fixed double roller bow fitting if it is matched to the dimentions of my Delta?
- I have noticed that the latest production yachts, designed to accommodate modern anchors, feature non hinged double rollers in what I term a "drop-head" profile i.e. the main forward roller is below deck level. This drop-head profile seems to negate the need for a pivoting double roller arrangement.
