Bigplumbs
That basically means that the agency wants to make it clear that under the existing regulations, you should not be working on your own boat!
More twoddle
Total Twoddle I am afraid you obviously don’t understand that the law in this regard in the Uk does not stipulate who must do work only what must be done and to what standard.
Erm, I'm wondering if you read the paper? If somebody dies on your boat, you may well find yourself in court on a manslaughter charge, which would look at whether you acted negligently or not.
The law may well not set out who you can use, but it, and insurance companies, will look at what is reasonable in order to assess whether you've been negligent/reckless. This paper, in setting out best practice, defines what is and is not reasonable (best practice), so will become hugely important.
My example is extreme to illustrate the point, but I can't find anything in his post that I disagree with.
I read so much on these forums from theory mongers, paper pushers and people who most likely don’t own a hammer or any other tool. Quite frankly I have no interest in their advice.
People who rely on paper trails are sad individuals who can be easily duped.
How will a paper trail help you when you are broken down at sea with no tools or the ability to attempt a fix. I surpose you could use it to wipe your rear end
If a Government Agency starts going down the road of trying to wreck the marine leisure boat industry there will be an outcry.
The word ‘consultation’ was obviously missed!!
Really?
Yacht owners are very much a minority, and not one that tends to attract much sympathy from the population at large.
When I was a 'consultant' we used to joke that the word 'consult' was made from 'con' and 'insult'.
If we all said to the MCA "keep your nose out of Pleasure sailing" I don't believe they would take that onboard. They have their agenda.....Then again I guess you think they should be involved.Yeah, all the instant experts on here now gotta front up or stop grizzlin!![]()
I have absolutely no idea what you have just said.
I have several parts that give me the willies, but I will reference just this one:
"Any damage to a vessel, regardless of the scale or location of that damage, should be fixed promptly, ideally before the next passage"
Read this in the context that each word included in a document is included for a reason and carries equal weight."
"…regardless of scale or location..."
This leaves no room - if you do not fix all damage, regardless of scale or location, then you are not complying with the guidelines. So that's any damage, anywhere, however small.
Now you can say "don't be silly, they don't mean that". But I can't see any other reason why you would so explicitly go to the trouble of including those words "regardless of scale or location" unless you intended them to be there, and that is certainly how a court or insurer would be entitled to read this document.
So to answer your question, there is one example amongst several of what I believe is wrong with this proposal. I'd add to that that I am have never commercially worked on engines, or gone on a diesel course. I read this document to mean that I should no longer service my engine. It makes no distinction on its guidelines between personal boats, and chartered boats with paying passengers.
Me no likey.
