The Dinorwic Centaur
all candidate boats considered
four adults and a lab
Katie L would burst at the seams
as for this one if it went for £500
pressure washer inside and out
replace upholstery with foam rubber covered with fleece
scatter cushions
Origo from Katie L
battery nav lights
some paint
replace standing rigging where necessary
as long as the keels are okay I am in business
having said that.... there are better boats out there with jiggered engines
yours....
Optimistic Ollie
Yep, and just one or two other items. Osmosis treatment, replacement of every bit of rotten wood on it (should only take a few months), several thousand quids worth of foam rubber, wood, mastic, paint, epoxy, glass, batteries, wiring, running rigging, standing rigging, chain. Probably a few hundred quids worth of sail repairs, a working VHF, new water tanks, rebuild kits on the bog, the taps, the winches etc etc. Then you can launch it (craneage) sail it for a bit and run round fixing all the leaks and things that go clonk and don't work. And then there's the dreaded "procedure" with the chainsaw.
Dylan my Sabre had sat ashore for 10 years when I got her. She was properly packed away and dry as a bone with a decommissioned but low hours inboard...I spent months, full time, just getting her back together and launched, and a shed load of cash too. I had the same outlook as you, a quick bit of this and a little bit of that without spending much, but the reality simply isn't like that.
I think your project is great but there have got to be better boats than that!!
600kg
Greengate Metals are offering 10p/kg on cast iron (http://greengatemetals.co.uk/scrapmetal/prices/). I am pretty sure that Centaur keels do not weight two tonnes each.
600 kg each for each keel
250kg for the engine/gearbox
50kg for the rudder
the aluminium mast will weigh around a guessed 100 kg
say 50kg of stainless gubbins
found these prices here
no idea how accurate they are
but my guess is those will more than cover the cost of crushing the plastic bits and taking them to landfill
especially if the same bloke buys several boats
D
... four adults and a lab ...
How long are they going to be staying aboard with you? It would be a major undertaking to bring a boat like that to anywhere near a family habitable & seaworthy state. Is it worth it? The money you'd spend would pay for quite a few nights' B&B for the overflow from Katie L.
Add to the above costs shifting it , just cost me £500 to move a 22 footer, the guy has a big hiab so lifted on and off but still a fair sum, especially if you consider the cost of buying the boat is probably less that the haulage costs.
Your points are good, but only for someone undertaking a full restoration, not for someone wanting to put together a simple camping experience to use for a few months. I still think the bulkhead's a biggie, though.
I,
that is a fine and sobering list
and you are of course correct it would be a lot of work if aiming for perfection and a cosy weekend retreat
my standards are not as high as yours
my family are as hardy as I am
more bivouac than frame tent if you understand what I mean
lots of the costs you identify will not apply
as I already live and sail without them
water tanks.. plastic cans from Katie L
radio.. hand held from Katie L
Osmosis - never gonna fix that
heads... should be fixed -assuming it needs it
Berth cushions 3 inch ebay foam and fleece covers £200 for the lot
Lilos and fleece covers even cheaper
batteries - Katie L runs on old car batteries - leds really are a game changer
cooking stuff - mopved over from Katie L
no wiring needed - leds and battery nav lights transferred from Katie L
Wessex are paying for all the epoxy
never use anti-foul anymore - not worth it with a bilge keelers and the frequency of drying moorings
varnish - got that in the garage
standing rigging - replace as necessary - careful inspection and replacement of dodgy eye splices - dyneema is a game changer when it comes to replacing rigging screws with lashings
running rigging - bags of the stuff in the garage
sails - who knows what they are like? lots of ebay ones around
So if this one goes for say £800 that leaves me with £1200 for the other bits compared to £2,000 for one that needs little more than the old engine removed and the well installed
yours
Hard as nails Henry
In pic 8 there seems to be a tide mark about a foot above the current water level. Are you sure the hull is watertight.
Walk away Dylan, don't look back. The right boat will appear.
That's blown my theory of a recent ingress of water out the window...!
Roger Bull the worlds most authoritative Centaur anatomist worked out the scrap value
stainless steel, steel, aluminium
Roger said that the value of the metals more than covered the cost of disposing of the GRP and left you up a couple of hundred
the keels are worth £400
the mast - maybe £50
stainless bits... £20
D
Christ Dylan if my keels were worth that much my boat would've been weighed in by now, i think this is what you're on about from something i posted regarding the disposal of grp boats:
"I worked it out after having a bad week on my project, phoned the local re-cyclers up the road from me to tell them what it was (Centaur - fibreglass boat) and they quoted me £100 a tonne so you could scrap a Centaur for around £150 - £200 then go weigh the keels in at 600kg a pop and the aluminum mast which weighs around 40kg (bare pole) and the stainless, and then..................... basically i would've offset most of the the cost of the fibreglass by weighing in the metal but only if i did the hull and deck in a weekend. At the time i could've had it done in a matter of hours the way i was feeling (hull refused to dry)."
So you're only talking a couple of hundred quid tops for the metals to offset the couple of hundred odd quid you'd spend scrapping the structure.
I couldn't agree more with you Iain hence I told him not to touch it with a bargepole.
cheers
The dealbreaker is that this project is not affordably towable, which may be a first for the OPs boats to date?
I have rebuilt a 26foot 'sail away' and enjoyed the process hugely and the sailing and racing afterwards but, I was not in a hurry. AND commute time to the job site was one minute on a bicycle and NO yard fees as we know 'em...
Family of four plus dog would be a squeeze in my 36ft I reckon, even with two dinghies, space enough and all weather comfort .
Lot of hanging around to get round Scotland in reasonably stable motoring/sailing weather?
I hate pouring cold water on people's enthusiasm per se and have to assume this is part of a well orchestrated DW enthusiasm and best of luck whichever choice pops up next, Keep Tackling Locations!....
Dylan
Sorry have not been feeling good and not up to a second photographic expedition....
We were preoccupied with getting 0ur boat safe. We had a bit of a tidal surge on Friday which was enough to overtop the dockside that Anna Sira is sittin on!
There is a 2005 harbour dues sticker on one of the windows which was probably the last time she was afloat!
Gareth is the property developer/owner of the Marina.
Hope to be in better health next weekend and do a bit more poking around for you.
Do you think cracking a sea cock or a little bore hole just aft of the prop would help in making an assessment of the internals.........
Steve
get well soon
Dylan
Steve
S
get well soon
not sure that crud should be drained into the sea
I am assuming it smelt of diesel - maybe not
if it smells okay then I guess a hose would drain it out
is there no hatch on the bloomin thing
some-one has drained some water from her to account for the fall in level
not sure that you should drill a hole in her
it would be great if you could poke the bulkead though to see if it has gone mushy
and a snap of the top of the keels from inside would be great
although I am beginning to think that she could be a massive amount of aggravation
2005
eight years abandonned - bumma
D
Okay I'll say it Dylan,
this is a good time for a rethink.
You're more likely to find a Centaur with a recoverable or quite likely servicable engine, they're good boats which appeal to novices and experienced alike, and usually worth a significant amount, so there can't be that many abandoned like that one.
If crew dictates you need a bigger boat temporarily get a normal Centaur by all means and benefit from the big engine for strong tides, battery charging - inc cameras etc - and heating one way or another, then sell her at the end.
These boats are either too far gone or too good to butcher just because an outboard manufacturer and a magazine are desperate, such a boat could go on to give a lot of pleasure rather than be a frankenstein experiment - a lot of people, me included, think if you're not doing it in the Hunter you may as well do it sensibly and there's nothing more pragmatic than a Centaur with good sails & ( newish, inboard ) engine - your videos will still be as good.
and
and a £10,000 price tag
D
So, dylanwinter, you want to take a shallow draft boat with a big hole cut in the cockpit around the top of Scotland?
Seeing as a chum got an excellent late model one with a brand new 3 cylinder engine & lots of electronics for less than 2 thirds of that I think not; yes he was very much in the right place at the right time, but Centaur prices seem to have tumbled more than any other boat lately despite their being a jolly good ( if not rewarding in helmsmans' feel on the tiller feedback terms ) boat in the right hands - I have sailed a few.
I'd think you could get a functioning useful one for £3,500 especially as this is just for one mission then selling on, not to become the family pride & joy.
...not sure that you should drill a hole in her...
