Bigplumbs
It certainly is a big project and kudos to you for taking it on
I spent a happy afternoon slapping paint on the now definitely upright and definitely floating “Llys Helig” today. Very agreeable crowd.
Her original 4 cylinder diesel engines had been replaced with 5 cylinder Gardners in 1929 and in 1961 these were updated with more modern 8 cylinder Glennifer units.From the technical drawing, the engines look a bit like large semi diesels. I know there are a pair of Gleniffers in there at the moment but not original.
She’s now fully patched with temporary patches. There’s still one leak at the stern which means the pump has to run for about 10 minutes a day.Interesting you say "definitely floating".
In one of the videos the man in charge of the operation pointed out that some large openings have been put in the hull specifically to stop it from floating.
Presumably this is so it does not fall over again.
As suggested previously it wants the excess non original steel work cutting off for scrap then the hull itself can be transported by a jack up barge and tugs to the shipyard for the rebuilding operation.
And I assume Chatham dockyard has higher standards than the high street..
This video
ETA looking at the date perhaps it has been since refloated with the 3/4 inch ply solution. If you can get 3/4 inch ply. Quite risky to float the boat if it is still top heavy .
One has to wonder how the MCA would view this type of repair. Yes it's okay to float the boat but would it be allowed for crossing shipping lanes?
I've no idea.
Has she been moved yet?
Yes, but that was 10 days ago and I had forgotten "The plan now is to do some of the structural beams and metal patches in situ in Burnham over the winter"Did you read post 145?
