Ex-SolentBoy
I have a Status 315 aerial with powered amp.
Yesterday, I had no signal at all. I plugged in a little non-powered reserve aerial and everything worked fine, so I know it is the signal from the mast-top aerial that has a problem.
I am intending opening up the various parts of the boat so I can trace the fault back to the source, but need advice on how to check the strength of the TV signal.
I know I can simply plug in a TV and try to retune it, but i was rather hoping there was some sort of gadget that I could use, like you can use a small voltmeter for testing circuits.
Any suggestions would be appreciated?
Thanks.
Thanks.
