lw395
Couple of problems here:
10mm microbore (from Wickes) has wall thickness of 0.7mm, giving cross sectional area of 22mm2, this is equivalent to 2.5mm dia cable.You have a serious bottleneck at the crimp.
Also, compared to copper, solder is a pathetic conductor, you should focus more on physical connection with solder there to hold things in place.
The resistance of a 2cm terminal is likely to not matter in the scheme of things.
But no-name crimps from ebay are likely to be better than home made, for a few pence.
Getting the welder maintenance bloke to put on a proper one still gets my vote when it's practical.
