davethedog
Afternoon all,
May have to remove the calorifier in our boat in order to get access to the port fresh water tank as thinking we have a slow leak in that tank that is putting fresh water in the bilge (less than 500ml a day but enough to be annoying).
SO, how easy to do this as understand it as follows:
Now if I could just get enough access to not have to disconnect the engine hoses it would be a lot easier!
DTD
- Drain the hot water from it by turning off the cold water feed and then running the hot tap until empty? Is this correct?
- Disconnect the water feed hoses for the domestic plumbing.
- Disconnect the engine coolant to calorifier hoses, how do you do that without losing all the coolant?
- Remove the tank.
- Inspect the area and get annoyed that you still can not find the sodding leak!
- Refit.
- Then how do you bleed the coolant to the calorifier? Is it a case of running the engine until the thermostat opens and then topping up the water level? then top up the header tank?
- Finally, what is this little access port thing on the calorifier hose for near the engine?
DTD
