gandy
Hi,
I finally got round to fitting tell-tales. On the main there are four leach tell-tales, one on each batten. I could do with some opinions on what they're telling me.
I was testing close hauled and on a close reach, with all the genoa tell-tells flying (except the very top windward that flicks intermittantly). Last time out it was maybe a F3, carrying full sail comfortably with helm almost neutral.
On the main the best I can get is the top and bottom leach tell-tales streaming, with the middle two being sucked behind most of the time. With this trim the mainsail luff is being back-winded. If I sheet in harder or pull the traveller up until the back-winding stops, all the tell-tales disappear behind.
Opinions?
I wish I'd taken some pictures .. the mainsail shape didn't look very good, sort of flat over some areas and baggy in others in a way that's hard to describe. The main is definitely old and almost certainly past it, but I want to make sure the controls and trimming can be sorted out as well, otherwise I won't get the best out of a new sail either.
Cheers.
Opinions?
Cheers.
