zoidberg
Needing to stiffen up the foredeck due to fitting a hefty U deck-eye for an inner stay, I queried my pet shipwright who recommended a chunk of underslung 1/2" ply as likely sufficient. Being me, I found two slices of 13mm grp sheet and have emplaced those, with more than adequate 'lots of sticky gunk'. The U-bolt legs protrude through. So far, so good.
The next step involves the attachment of a 'spreader' plate of 3mm stainless underneath the above lot of grp plates and sticky stuff. This is about 35 cm x 18cm and has a 50mm lip, and I can fit this onto the screw-legs of the hefty U-bolt, either way up. Here's the question...
Is it likely to matter significantly which way the lip faces - up or down?
