ip485
Hmm a bit like describing chipboard as pine or whatever tree the chips come from.
Definitely that; perusing their website shows that it's available in thicknesses between 0.4 and 2.8mm, so for robustness or to offer the possibility of refinishing you could pick something from the thicker end of the range. ALPI also do pre-finished veneer, so you could opt to skip the hugely tedious varnishing bit.But the Alpi teak veneer is made out of teak, just not a veneer cut from the log in the traditional way.
Not at all, these engineered veneers are excellent giving consistent quality from a slightly more sustainable source.Hmm a bit like describing chipboard as pine or whatever tree the chips come from.
Not even sustainable plantation grown?Not at all, these engineered veneers are excellent giving consistent quality from a slightly more sustainable source.
Do not be fooled by an fsc label, we should not be using any tropical hardwoods other than reclaimed timber.
Yup it's an interesting point, my sense is that there are two main issues with sustainable plantation growths -Not even sustainable plantation grown?
I’m not sure if that is correct. I believe the product is reconstituted wood. … but I think teak refers to the style and design rather than the timber used.But the Alpi teak veneer is made out of teak, just not a veneer cut from the log in the traditional way.
Bamboo is a member of the grass family and certainly grows faster than any timber. The fastest growing can increase by up to 48" in a day and the largest variety's diameter is 12". It is a very good for some uses, but does have some problems. Back in the 1970's my father was involved with bamboo in many areas of the world and trying new uses. The most successful at that time was woven bamboo boards 2400x1200mm made in Thailand, which was later badly copied in China. It was and would always be a labour intensive process and meant is was a premium product used mainly for decoration purposes. The largest problem was getting the glue to successfully bond to the bamboo, followed by the timber industry having everything geared to a plentiful supply of timber. The supply of timber has now dropped compared to the demand, but the glue problem may now be solved with further research. Compared to timber the bamboo boards were very tough and waterproof, but were never smooth and used a huge amount more of the glue compared to plywood. This will never change due to the structure of the bamboo. There were trials in Taiwan at trying to produce a bamboo chipboard, but the glue cost stopped production as it cost too much to make. I had always thought that the timber industry should have investigated bamboo as a material, but it just seemed like an alien material that was not a tree and had a hollow centre, so was bulky to handle for the small volume of material that could be used as the outer and inner skins had to be disposed of (read burnt).I'm hopeful that engineered bamboo produced with non toxic bonding will provide part of the solution.
That's a v good summary of the issues around bamboo board production, however the industry's developed massively since the 70's. If its worth engineering v small section softwoods into only slightly larger components (I'm not talking gluelam beams) then at some point the production of boards & other stock that shares most of the properties of increasingly rare hardwoods must become economically viable? Fingers crossed.Bamboo is a member of the grass family and certainly grows faster than any timber. The fastest growing can increase by up to 48" in a day and the largest variety's diameter is 12". It is a very good for some uses, but does have some problems. Back in the 1970's my father was involved with bamboo in many areas of the world and trying new uses. The most successful at that time was woven bamboo boards 2400x1200mm made in Thailand, which was later badly copied in China. It was and would always be a labour intensive process and meant is was a premium product used mainly for decoration purposes. The largest problem was getting the glue to successfully bond to the bamboo, followed by the timber industry having everything geared to a plentiful supply of timber. The supply of timber has now dropped compared to the demand, but the glue problem may now be solved with further research. Compared to timber the bamboo boards were very tough and waterproof, but were never smooth and used a huge amount more of the glue compared to plywood. This will never change due to the structure of the bamboo. There were trials in Taiwan at trying to produce a bamboo chipboard, but the glue cost stopped production as it cost too much to make. I had always thought that the timber industry should have investigated bamboo as a material, but it just seemed like an alien material that was not a tree and had a hollow centre, so was bulky to handle for the small volume of material that could be used as the outer and inner skins had to be disposed of (read burnt).
It is an excellent article, worth putting it up as a thread in its own right?Production of most derivative wood boards and reconstituted timbers uses so much energy and plastics you might as well fit Formica. -)
One answer may be to use plantation timber which should be possible on a 40 year cycle. However getting people to invest now is impossible while present controls remain so leaky.
The real fix is to find other timbers especially for the more mundane things like interior cabinet work and keep the use of all man-made board to a minimum.
Here is a very good article by Jessie Rogers whose yard started looking seriously at this over 10 years ago:
The dirty truth about teak - Yachting Monthly
