Tassimo won't work on inverter
Hi
Just for your further information.......
I have a Victron 2 kva Invertor / Charger that runs my Tassimo without problem.
We have a 460 amp hour battery bank and whilst running (only for a minute as you say) it is drawing about 170 amps from the batteries.
I suspect it is the power being delivered from your Invertor is the problem, it may well be not pure sine wave output.
Graham
And I run from just 1 110ah battery ... Dedicated to the inverter but fine for running what I need just in emergencies ... If it was your supply the inverter would trip out and stop working so it's no way your supply... trust me!
Most inverters cut out when they have low supply voltage so if your coffee machine is blinking the inverter is still running so has a supply that is good enough and it's the output on the 240v side it dont like... If inverter had low volts or poor supply it would cut out and not provide nothing. We use cotek inverters all day every day and put them through hell on our company vans . We use them running flood lights power tools and computers on our vans with just a split charge system by fords with a 95ah secondary battery under the driver's seat and we have no issues (but we have vans running a lot)
Ian
Time to put a few ghosts to bed with a bit more technobabble.....
Pure sine (not sign), modified sine/square and square wave, lets have some pics...
The grey and blue are the target, a pure sine wave, mighty fine for running motors, transformers, national grid and kettles. Not so hot for electronics.
Electronics need DC, not AC and at a low voltage. Used to be done with a transformer to drop the volts, a diode (or 4) to make use of the -ve bits (half the storey) then a stonking great big capacitor to store power for the lean time (where the sine wave goes from +_to -).
Now, enter the modern world with fancy switch mode power supplies, more efficient, smaller, lighter and cheaper to make. Whats not to like? Well, its how they work, you see. As per the name they switch, they switch the supply on and off (very fast) as required to make the desired output. At peak mains voltage they turn on only a small % of the time, at zero crossing (+ to - and back again) they are on longer. Meaning you need a much smaller capacitor to store the energy for the lean times.
Great for sine wave, and just dandy for square wave, both these have a reasonable voltage most of the time. Now, bring in the modified sine(square) wave and the problem becomes clear. In order to easily, but better mimic a pure sine the modified sine has long periods of nowt, not an electronic sausage for what is aeons for switch mode PSU.
What a great post, thanks. There's been some really informative posts on this thread - except for this one:
which was just bloody rude. The forumite to which this was directed in Bartw, who is a big contributor to this forum and imho should be treated with a bit more respect. By all means disagree with his post, just don't be a dick about it.
Thanks all, I now know an awful lot more about inverters than I did before :)
GLS, good to know that it does work on a pure sine wave inverter, thank you!
I do have a suitcase generator, but it's far too antisocial to fire up at 6am which is when I'm most in need of a coffee.
I'd really like a small diesel gennie installed, but it's not really worth the cost for the limited amount of time I get on the boat. Plus, space is very tight in the engine bay as it is without taking any more away.
I think the best longer term solution is to replace the inverter and carry the suitcase generator on board to top up the batteries if needed.
In the short term, a fiver on a cafetiere seems to be the way to go!
From experience with our Nespresso machine, if you get a new pure sine inverter, go for one that can deliver at least 20% more, continuously not peak, than the stated wattage on the coffee machine.
Thanks for that, i'd go for a 3KW continuous if I replace it. Extremely unlikely that I'd need that sort of power output, or want to subject the batteries to that! But, nice to have the option for not much more money.
... switch mode power supplies, ... At peak mains voltage they turn on only a small % of the time, at zero crossing ...
I think you are confusing a SMPS with a dimmer. If an SMPS has an AC input, then the first stage is to convert the input to DC. It is this conversation that is confused by MSW.
Apologies if my "twaddle" comment caused offense. Everyone speaks twaddle on occasion, even me :)
I had an inverter on my first boat.
It was great but kettle or toaster would kill batteries. Solution was just to run both engines on high idle and cross feed the batteries so all batteries and alternators were helping. Given it was only in use for maybe 5 mins it was a small price to pay!
As an extra comment to my reply yesterday, I have always thought when the Tassimo is running on the boat, it doesn't sound as "powerful" when running on the Invertor compared to running on shore power.
It always gets the job done, the coffee reaches the same temperature, I have always thought it just sounds like it is near the top of the range of consumption for the Invertor.
I have the same Tassimo here at home, so I turned it upside down this morning to check the specification of how much power it uses.
The label says 1,300w but I strongly suspect that it needs all of a 2 kva Invertor to work correctly, my guess is that a 1500 - 1600 w Invertor would not be suitable.
Just a guess, but based on real world experience.
Graham
Graham
Thanks Graham, very interesting! Funnily enough, when mine did work (before the error lights came on) it did produce coffee, but it didn't seem to deliver as much as usual, and didn't produce the big hiss of steam at the end.
That's got me wondering now... about the power consumption figures are actually calculated. I'd assumed it would be a maximum draw figure, but maybe it's just a mean?
The whole idea of putting the tassimo on the boat was based on it's power consumption, which in theory would easily be coped with by the inverter. But, if an appliance is peaking at a far higher figure than that stated, that could put a whole different slant on what's suitable to run off an inverter in the first place. Or, what is acceptable to subject the batteries to!
All a bit theoretical really, I know mine has the capacity, it must just be the waveform that's wrong for it but it would be nice to know the maximum consumption of devices to be able to assess whether they're suitable in the first place.
As I said earlier, mine is discharging about 175 amps on the Battery gauge while it is running, only for a minute or two, and total draw from the batteries is not great for a cup pf coffee.
I also note my Victron 2000/12/80 does have the ability to put out double its rated 2kva for short periods of time.
Graham
Does it damage the batteries drawing such a large load, even though only for a short period of time?
I guess that at some stage, theoretically, it would be possible to have such a large inverter, with full load, that the batteries would effectively be in a dead short when supplying the power?
Edited to add: And going by your figures GLS, with my very crude understanding of electronics (and given no other load on the system other than the inverter losses) that your tassimo is actually drawing over 2KW at 175amps discharge?
As has been said earlier, great thread with very informative input. Thanks, but with me and I suspect others, it has posed more questions. To run a normal domestic fridge with motorised compressor, which of the three inverter types should be used, Square wave, Modified wave or True sine wave.
To say batteries are happy with high current is a bit general, some arent, some are. Consider what your engine takes to crank it over, hundreds of amps on truck sized batteries is just another day at the office, nothing special. Leisure batteries are another matter though.
The biggest problem you will have is that most high current batteries arent fond of being discharged for very long, vehicles draw loads at start but top up immediately.
You would need to check the battery documentation carefully to see if what you have is right for the job.
