jacobjohn7
Please bare with me as I have several queries with regards to doing up a project boat, more detailing than anything, but getting it to stage where I can detail it will be good.. feel a bit obsessed and desperate for answers/help
... here goes
1. Aluminium frames on 70's fairline, some more tarnished than others... some with sticky residue on of left over pulled off 'gaffer'? tape.. I've been using brasso as a starter from rec's I have had, any other ideas to remove heavier tarnishing and slight rusting stain around screw heads on front screen.
want to get these back to full 'shiny' glory. Hope I can. Ideas please.. brillo? other pad?.. thank, any help appreciated.
2. Old fixing for side openers have come off or snapped with the screw fixings still into the fibreglass? have some of the original bits and pieces, would it be good to just get new sets of locks... but the main question is if I take out the original screws from out of fibreglass side and bearing in mind its an old boat.. will there be something to screw into, prob not just an hole, but how would you create something of substance to screw into so that its secure once fixed. Any help appreciated.
3. The canopy area is prob the original, its more or less intact and is not far off as it prob ever has been on the sides. But the top has had wear and has gradually lost most of its covering whatever it was.. looks like a vinyl type covering on fabric. I have on order a renovo set with blue colouring and restorer etc. but have a feeling the restorer wont be substantial enought as from the inside there is bits of light where bits have got flaky and thin. Is there a product that kind of pastes on thicker like a rubber compound in blue to restore the top that way? thanks, and brilliant ideas appreciated.
4. White bodywork of boat... I have on order some rec'd product G3 compound for removing and residue etc (not sure how much it will take out) then intend to to use an auto glym type resin polish... but with this going onto what is now a matt body work what is the rec'd technique to get some shine back to the body - if at all possible? or is a new gel coating needed to paint on before this to get the shine back?
5. top opening vent just above sleeping qtrs in bow... this is fibreglass with no gaskets and when I was washing looks like it was letting in water easy, may be different with rain coming down, and product/suggestions for making a better seal? maybe just simply a bead of silicone round the apperture into boat... or rubber gasket that hangs down stuck round the inner sides of top vent piece
Think that should keep me going for a while I hope some people can help out! Thanks all.
