Appleyard
Another possibility is to drill it all out and fit a stainless thread insert(I forget the trade name......). The hole is tapped out with a special tap, the insert screwed in, a tang snapped off and a stud of the original size can then be screwed in. But will only work if you are drilling into solid metal. Most engineers can do it - not worth buying the complate kit as it's expensive.
Helicoil
