GHA
Not really been paying too much attention, so you have a new sensor which outputs 1.6v empty to 3,8v full, and another gauge which wants 2v empty and 4.5v full - 'i now have an signal of 2.0V with the tank empty and 4.5V with the tank full'tnx Roger
signal voltage with no water in the tank = 1.60V
tank full 3.80V
this is in the dashboard:
VDO Viewline Onyx Freshwater Gauge 12/24V - Use with VDO 10-180 Ohm Sender
link
(i don't have an 10-180 Ohm sender obviously and no access to the top of tank to fit one either)
can an analougue amp be designed build for this ?
And arduino should cope with that esy enough, there's even a function for just that > Arduino Reference
You can set one of the pins as an input to measure voltage and another to output, it's not actually a voltage but turned on and off really quickly, your guage probably wouldn't notice.
Arduino PWM Tutorial
