TAMD74 Exhaust Manifold service
Erik Forslund
24 Apr 2022
I plan to replace service gasket kit on exhaust manifold and need some tips in what to remove.
I guess:
* drain coolant system
* front connection to water pump
* all 6 fuel pipes to fuel pump
* fuel filter holder
* coolant connection to turbo
* main exhaust connection to turbo
* Black box for electronics
The question, can i leave turbo as is, or do I need to unmount both turbo and aftercooler in order to remove the exhaust manifold?
Any practical tips are appreciated since I plan to solve this by my own.
/Erik
I guess:
/Erik
You can leave the turbo as it is but you have the weight of it plus the exhaust on the oil return pipe and the bottom water hose , unless you rig up a strap to support it , you might also find the manifold needs to be eased out the 4 studs that are screwed into the turbo plus you can dislodge the rubber O ring which is recessed into the manifold , I would glue it in the day before you fit it back on .
Might be worth having your turbo overhauled at the same time , I’m actually on with the same job this week.
Thanks, probably smart to remove a bit more than you need
I have now started to remove some items to get access to the manifold. Solved fuel filters, EDC-connection, black box, fuel pipes, turbo nuts.
Still some questions about two things, any tips are appreciated.
1. Turbo, when removing the manifold and since I plan to leave the oil pipes from turbo to the block, will it be pressure on them, or will the turbo be kept fasten to the air cooler?
If I need to remove the oil pipes, how should I best handle that? Check picture on turbo oil pipe, I don't know how to treat those.
2. Waterpump, since the turbo will be left, I will not have that much space on the manifold frontside at the water pump. I have removed the last piece, but wonder if it is possible to remove or flex the pipe a bit, and I don't see any other connection to remove. See attached picture and the schema on no 40, 41, 42.
