Reflection
Hi all,
My port side engine has started losing coolant when driven hard, can cruise all day at 8kts with no problem but once I exceed 15-16 kts she starts to lose coolant, approx 1L over an hour running
-No evidence of water in oil
-No water being expelled from top of expansion tank, so don't think its head gasket. Also carried out a compression test a short while ago when refurbing injectors and all was good
-No water in gearbox oil
-No water in bilge
Exhaust manifold to turbo gasket is known to cause this problem but mine has earlier been replaced by the newer steel type which is supposed to solve this problem.
not seeing any evidence of rust runs down side of engine which I believe are a sign of leaky exhaust manifold gasket.
When I got the boat 18mths ago this engine had quite rusty water whilst starboard was clean coolant. At the time I flushed it out and added new coolant (Volvo) to both engines, both coolants still look nice and green.
Currently have main heat exchanger off being pressure tested but from some crude DIY testing I suspect it is OK.
Has anyone else had similar experience ?
Rgds
Richard
-No water in bilge
Rgds
Richard
