crazy4557
I have the standard Volvo EDC on my engines. Starboard engine runs and revs out of gear fine. Port engine runs and sounds fine in neutral but is very lazy when you open the throttle and doesn't want to 'rev up' when you blip the throttle in neutral. When under way at idle speed if you open port throttle on it's own you get very slow acceleration/response. Open both throttles equally and port engine behave's fine. Both are similar max revs at WOT. No extra smoke and temperatures are rock steady.
Does anyone have any clues as to the issue here? This happened last year but seemed to go away after a while when the boat was used frequently but with hardly any use this year the issue is back.
I'd like to know that it's not a potential big problem as we're off for a 3 week jaunt next week.
If anyone has any clues as to what it might be I'd be very grateful.
