guardian
In this economic environment walk away....................
Avoid sealing the whole hull in epoxy coats as that will make the current situation worse.
You will have to ask for advice as to which additive to thicken up the epoxy for filling and sanding would be best.
what part of the question is that an answer too the guy asked shat it was or how to fix it.In this economic environment walk away....................
It’s been bead blasted that’s all. And if he got it at a good price at 2k and spends 1k in it he’s got a bargain.That looks more like a building that has been riddled with automatic weapons, as guardian has said walk away you will fined a much better boat that costs less than fixing that one up!
I spent two years of my life and countless thousands of pounds doing what he's asking advice on, seriously walk away.........................just walk away.what part of the question is that an answer too the guy asked shat it was or how to fix it.
Depends if he likes fixing boats or going sailing.It’s been bead blasted that’s all. And if he got it at a good price at 2k and spends 1k in it he’s got a bargain.
I read it that he already owns the boat .
No fairing is needed as the hull shape is not being removed, just filling lots of small holes.
If he was a plasterer he could fill and sand in a weekend.
A flawless finish is not needed. £500-£600 ? Filler, sanding discs, primer, antifoul, sailing ! (And a fair few hrs)
"Presumably he bought the boat very cheap"
But as mentioned here and everywhere else even a boat going free can still be too dear given its age, condition and secondhand value, FWIW here are your options as i see it:
a) live with the blisters & go sailing £0
b) fill and fair blisters with watertite or equivalent (as above) £500
c) (I took this one) Gel peel and hot wash till the numbers come down then sheath in bi-ax cloth & epoxy x2 then barrier coat x 5-7 (between 1- 2.5 years of your life depending how stubborn your boat is at 'drying' and about £3 - 4k in tools & materials for a 26 footer. Not to mention renting/building a shed to control temps and humidity for the duration of the job, another £2-3k and that's doing it all yourself.
At best, looking at the pics your gelcoat (as mentioned above) has failed and the blisters are 'surface' at worst waters in the laminate, hence the 'walk away' comment. Go to Nigel Clegg's excellent site and download the PDF's freely available on osmosis this will help you understand whats going on with your hull.
But for my money given the potential deflationary collapse we're heading for here and elsewhere post covid any money spent now could well be regretted later, & as many will tell you here boats have a nasty habit of costing a lot more than was budgeted for so unless there's any localised softness of the hulls laminate, i.e you can push it in ( physical deterioration of the skin) option a' your best bet.
A good book (which i should've read before i did what i did); Hugo Du Plessis' Fibreglass Boats
Not really. I massively underestimated the amount of work a peel would create, plus i was into doing things 'properly' back then, now i'm semi skint most of time its amazing how you find alternative ways of remedying problems. Now if i had my time again i would never undertake such destructive costly work as a full gelpeel and repair especially now given the near freefall in secondhand values of boats. In heinsight, after reading Hugo's book i should have peeled locally, in my boats case just the keel stubs.Thanks guardian,
It sounds like you must have really wanted the boat for option C, I bet that kept you busy.
At the risk of sounding like I'm teaching granny to suck eggs. Going back to a few points on here. Two of them specifically stand out for me is not seeing any evidence of osmosis treatment and the holes looking like it's just been shot blasted. I'd also read elsewhere re. blasting a hull that you should prepare to see "voids" where it has dug material out.
Again, I would defer to the knowledge on this forum, however it does sound like I'd be going for option B? I appreciate everyone's comments regarding should I/shouldn't I. I will be doing it.
Thanks again.
