Guy
I have a Vivacity 20, with an alloy mast just over 20' in length. I am having trouble with the stays (they are too long - and I'm waiting for some Noresmen terminals in the post) but that's not the question for now.
The tabernacle has two bolt holes. The top one is the fulcrum for raising mast. Then there is a bottom one. Last season I sailed with both bolts in and a 10mm pad of wood to fill the gap at the base of the mast (between base of mast and base of tabernacle)
In a sailing magazine I saw a similar tabernacle with the fulcrum bolt removed. This got me thinking.
At the moment, I know the stays are too slack and this is what is happening:
Downwind, mast has a bend forwards (if you look up the mast track), so I go back and strap the two rear stays together to get the mast straight).
Then, when I'm on the wind, the mast has a bend aft.
So that means the base of the mast is held firmly, yes?, but the top of the mast isn't - there is no equilibrium between the forestay and the two rear stays, is there?
Is that right so far?
Now the stem head bottle screw is real tight (i think - roller furling gear makes it hard to tell - bottle screw is really tight by hand, put it that way) and almost to its limit of turns(I should say the forstay is 6mm diameter and the two rear stays are 4mm each), but the rear stays are not really tight. If I tension the rear stays even a little bit, they bend the mast backwards (but the tension in each rear stay only has to be half the tension in the forestay, yes?) So this bending backwards doesn't make sense to me first of all.
I thought I'd take the bottom bolt out of the tabernacle so the mast could pivot (that'd get rid of this bending, yes?) CAN I REMOVE THIS BOLT? IS IT SAFE TO SAIL LIKE THAT?
Then, I'd rake the mast back a bit (that'd extend the stemhead bottlescrew a bit so I had some turns to play with) and I'd cut the two rear stays shorter, and try to get the proper tension on them (seriously, they flop about at times).
HOW DOES THAT ALL SOUND?
I don't think the hull (grp) is distorting.
Any advice welcomed.
Thank you.
Thank you.
