Spanjaard
First of all, I would like to wish you all a Happy New Year.
As part of the maintenance works for this year, I decided to strip out the old treadmaster that must be about 45 year old and that has bubbled up on multiples areas of the deck which is aluminium.
But as I started chipping away the treadmaster, I found that all fittings, including the tabernacle, the balustrades and the cleats have been mounted over the old treadmaster.
I am planning to repaint the deck with kiwi grip or similar non-skid paint. However I have the dilemma of reinstalling all fittings including the tabernacle, metal against metal, or if I should install rubber gaskets in between the fittings and the deck for better grip and to prevent any leaks.
At the moment I am cutting the old treadmaster around all fittings and probably I could paint the deck without removing all balustrades, cleats and tabernacle, with little or no difference...
I don't know if I could bear knowing that the old treadmaster still remains on some places as I hate bodge jobs, even though, removing all fittings is going to be a pain and will require a good dose of testicular fortitude and determination.
Any advise will be appreciated.
