MystyBlue2
Hi all im new to this site and relatively new to boating so my apologies if i sound as thick as 3 bricks from time to time.
I have a mariner (jap origin) 25hp 2stroke 2cylinder outboard 1980.
I have been trying to investigate a rough idle/misfire as my top cylinder was not firing after doing the lead test. Anyhow i put in new plugs cleaned the inside of plug leads with cotton buds give a spray with WD40 and top cylinder is back working again. I have 2 problems...FIRSTLY if i switch the plug leads to the oposite plugs it makes no differance at all to the motor running or starting and dont know if this is normal or an indication of a faulty coil pack or CDI unit as in a car its a big no no. SECONDLY it is very smokey and i know 2 strokes are smokey but i would expect it to smoke when cold then get less smoke when warm. However this it the complete opposite. Hardly any when cold start then lots of smoke the warmer the engine gets. Plugs have been in 8 weeks and fouled up already. My carb mixture screw is set to 1 and a half turns out from lightly seated and running 50-1 ratio with TCW3 outboard oil. Also very very low on power too dont know if any of issues above could effect performance but shes mounted on a 12ft seahog boat and struggles to plane. Average 10kn max!
Sorry for the blab just wanted to get as much info as i can,
Looking forward to your replies cheers in advance
Dan
Dan
