25931
Do you have a lead on board ?
Do you ever use it ?
Have you ever armed it with tallow to check the bottom ?
I keep a lead line in the dinghy and will often use it to check depths after I have anchored to see if I can tuck further in to the shore, or come in really close and run a line. Never used tallow, if I cant see the bottom I am not interested![]()
And sometimes you still can't see the bottom.In our part of the world if you CAN see the bottom you are aground.![]()
+1Yes.
Yes.
No.
Used to check accuracy of the sonar.
No, but a winch handle on a suitable bit of cord has worked fine!QUOTE]
+1
I thought about the ribbing that I had endured from mates and wife after using a winch handle as my sounding weight, when I read this thread.
However, now I can retort that there's another person out there who 'is just about to lose my favourite winch handle by using it for something that it's not supposed to be used for'. And he's a real sailor!
Cheers
Garold
+1
Cheers
Garold
*I should find some more, its the same Tallow its had since I was a boy probably 3 generations old.
No, but a winch handle on a suitable bit of cord has worked fine! In fact, I've only ever used it to check the offset on my depth-sounder - it wasn't documented when I bought Capricious, and in the waters I sail in, it isn't immediately obvious what the offset is (turned out to be set to below the keel depths).
*I should find some more, its the same Tallow its had since I was a boy probably 3 generations old. Never used to test bottom in anger but often interesting to see what comes up...
Don't risk a winch handle. Use a ring spanner.
I have winch handles on board; don't have ring-spanners!
