blackbeard
In several years of using a tidal swinging mooring (the "tidal" only being a problem at low springs):
minor issues with contact with another boat, with contact with another mooring buoy, abrasion of coving tape at bow by my own (hard plastic) mooring buoy, and abrasion of rudder against concrete block on sea bed. None of these were serious but the buoys were obviously too close together, and the buoy should have been of softer plastic, and a clean sea bottom would have been better. Just some things to watch for. If I have a swinging mooring this year it will be in deeper water, and slightly further from other buoys, so should be OK.
Biggest problem is the trip shore/boat which needs a reasonably stable dinghy, even so in more than F6 is not a good idea. You will have to row unless you can put an outboard on the yacht while standing in the dinghy which is not easy if single-handed, or unless you are happy leaving the outboard in place on the dinghy.
I have no qualms about leaving the dinghy on the mooring while I sail away but then, it cost me all of £20 and has the yacht name painted on it and the SSR carved into it!
Swinging moorings are much easier than marina berths to pick up and leave, especially if single-handed. They also give the feeling of being a "proper" yachtsman rather than being in a caravan park.
