MapisM
That's well and good theoretically, but the elephant in the room for using these separate outlets is that I have yet to find a boat whose AC circuit is designed for splitting AC equipment with high current absorption (airco, cooktop, etc.) from other "lighter" stuff than can be ran through an inverter.Overloading an inverter usually is not as dramatic as overloading a battery system so most decent inverters will just trip on overcurrent and shut down to protect themselves. The real danger is repeated or sustained overloads, since the thermal stress can shorten lifespan or, in a worst case, damage components if protections lag. That’s why people lean toward the separate outlets approach you mention it keeps the wiring dead simple and ensures you’re always in control of what runs where
So, using the "passthrough" AC outlet of the inverter for the former and the DC-powered AC outlet for the latter requires a rewiring that, depending on the boat, is anywhere between a massive headache and brain surgery.
That's the reason why in my boat, whose AC system can potentially draw up to 50A when running all onboard equipment, I connected my 3kW inverter to the general AC circuit, and when I'm neither on shore power nor genset, the instrument I use for limiting AC absorption is the good old common sense.
BUT, since I don't fancy the idea of stressing the inverter/batteries whenever the wife may turn the cooktop on forgetting that we are running on inverter, rather than rely on the fact that the Multiplus will eventually trip and shut down for protection, I wired a 10A breaker in between the AC outlet and the onboard AC circuit.
Which is more than enough to power the AC outlets for charging mobiles, keep the 5G router running, and also occasionally make an espresso - which covers our needs for 95% of the time we spend at anchor, while still remaining well below the max inverter capacity.
And if the wife forgets to turn the genset on before using the cooktop, it's a simple matter of rearming the breaker...
