Karnic
Hi Guys.
I have a Suzuki Ob 115 with a speedo exactly as the one in pic. Lately i was having an issue with the speedo and would like your views . While underway the gauge needle would not go up but when i accelerate the needle starts marking ( go up ). Before as far as im concerned the needle would mark even at slow speeds ex 15 knots but in order for needle to start going up i have to accelerate hard. After accelerating hard needle will start marking. Also needle sometimes toggle a bit up and down.
I would like to know if Either gauge is not working properly or the hole on the outboard is clogged. However i inserted a needle in the hole of the outboard to unclog it a bit but to no avail.
What Should i do? Do you think i should try to unclog the hole on outboard if its from there. Needle only entered hole few cm's. Should i try to unclog more or gauge is faulty?
Hi Guys.
