casper10
i have suzuki DT8 2 stroke which i presume is about 20 years old (but looks like new)
It would never start when i bought it. I took it apart and found the pistons rings were stuck to the piston. I free them and put the engine back together. but still wouldn't start. I have since given it to a mechanic who has stripped the engine down again replacing the gaskets ,scuffed the bores as he said it had a siezure sometime in the past. checked the reed valve is ok. The engine has a compression of about a 100 in both cylinders, the spark on both plugs is excellent, petrol is getting through. I can start it two ways
1. by using a drill onto the flywheel (not ideal).
2. or by pouring a small amaunt of oil in the cylinders ( a marine mechanic advised me to do this after the engine had been stripped down as it looses its suction/seal.by doing this it will start with the pull cord (sometimes!)
Obvisouly i need to get it going reliably, does anyone have any ideas to what the problem could be ??
PS I am using a mixture of 50:1 does this seem correct ??
I am a bit of anovice when it comes to engines !!
<hr width=100% size=1><P ID="edit"><FONT SIZE=-1>Edited by casper10 on 25/03/2004 21:50 (server time).</FONT></P>
