joliette
My Suzuki outboard is now 3 years old. It's had light / moderate use, powering my tender. I'm disappointed with the reliability. I recently replacd the ignition coil and fuel cap at a cost of about £50, which seemed high for a £300 outboard. The first time I dismantled the motor to clean out the carb I had to drill out a number of st. stl screws where these had welded themselves into aluminium - a problem that Suzuki should have prevented by selecting better quality materials or assembly techniques. Cleaning the carb is becoming a regular task, every other month. I think this could partly be due to the absence of an in line fuel filter, but I'm wondering if I'm getting some kind of reaction in the carb float chamber (as this is becoming pitted inside) which is producing deposits that block the needle valve.
Has anyone else suffered similar problems and found a solution?
